Chenn2389
I got everything back together. I filled up with gas and through in some Lucas octane boost. I am feeling engine vibrations starting at about 3k and up. It not super bad bad definitely shaking the dash caused my instrument lights to go out assuming plugs or grounds came loose. It does it in neutral and in gear with clutch in so its definitely not the drivetrain related. I am assuming its misfires or pinging. I double checked all the vacuum lines, I rechecked my fuel pressure is at 39 psi. I pulled my plugs and measured gap it was close to .050 on the motorcraft plugs they had a bit of the orangish coloring from running octane boost which is normal. I switch to autolite 3924 plugs, and gapped them to .035. Took distributor cap off cleaned it up. No change. MAF and IAC and all the temp sensors are new. Only thing I can think of is that I got a shitty tank of gas, or when I cleaned the TB when I switched out the IAC some break cleaner got into the TPS and now its bad, gonna do a voltage check on that to see if its bad tonight. Any one else have any other ideas on why it would randomly start vibrating like that. I ran the codes, I have the 02 sensors detecting lean condition for a second but it goes away. New engine has less than 250 miles. I am thinking the car is in limp mode. Anyone have any thoughts?
