Not right now but a buddy is pulling his cam and I get it for free I can't remember the size he told me. It will be stock setup with this cam. Heads will come later
Brought to you from a a land far far far very far veryy very far away
After Christmas ima go snag some gt40 heads since I had to sell my last set. These I'm not gunna do as much work to. Just some home porting and new springs and some 1.7rr
But I'm just asking about the cam for now. Thats why I'm not trying to change pushrods or anything. Cause they will need to be changed when I do the heads
like Slow said you should wait to touch the cam for when you do the heads and intake also. I think technically the cams would work with stock heads but being higher lift cams you'll want to install stronger valve springs and in turn probably stronger pushrods as well.
Ill be running stock longblock with diff cam (depending size i dont want a huge cam for stock heads.) home ported gt40 lower with upper. 70mmtb with matching elbow. Bbk longtubes o/r x with dumps. cai and aluminum ds
