cams in a 98gt
ROB 98GT
Heys guys!! I'm planning to do the pi intake and cam swap in a few weeks. Do I have the press on style cams? Do I have to get the cams from a romeo engine? I would like to do this the most cost effective way. Thank you.
Pennywise2
If you have a Romeo than you have bolt on cam bolts.
You will need the PI cams,cam bolts,and the AFM or Ford cam tool unless
you want to spend 3-4 hours taking off the front timing cover and
putting it back together.Don't skip a tooth on the timing!
Good Luck.
ck5.0
Damn you drop top.... Stop knowing everything........ O0 ;) Thanks
The knowledge is their for all to know...i just retain more in my big head then others :)
NORTON98
Where can you get this tool and should I expect a mustang shop to have or know what it is?
Mike
Rantheman
yeah he has a big head to go with that big brain of his.
Did i just say that :eek:
Pennywise2
Mike
Just ask them for the AFM cam tool for the 4.6L engine.
www.andersonfordmotorsport.com
All the does is holds the timing chain so you can qucikly
change camshafts without taking off the timing cover.
ck5.0
How long do you think replacing the cams would take (on average)?
98MSUGT
Is your car a stick or automatic?? I would look at the XE268h comp cams.
Tornbetween2
Do all romeo's have bolt on cams. Or just up to 98.
Do the 01 and up romeo's have non bolt on cams???
all the romeo have bolt on cam gears but the 96-98 and 01-04 have different size cam bolts so you need to get the ones from pi cams if you swap.
Tornbetween2
Ok well i have a couple heads that are press on gears, but i was told they were a 2000 and they have 11 bolt holes.
Any help there
press on gears are windsor...do you have the valve covers that came with the heads or no...the head i don't think will have 13/14 holes just the covers. What style cam caps are in? romeo has ladder style and i think the windsor has the individual.
TN95gt
