cams with best/highest gain?
Fryrice
steedastang said:
did you guys replace the chain, sprockets, and tensioners? A friend of mine recommended i replace them.
also: without pulling a valve cover how cani tell if my sprockets are pressed or bolted on? Its a 96 gt
How many miles on your ride ? I replaced my lifters with 92k on the odom. Went OEM on those .They were fine before the swap,but I didnt want the new cams pound them into submission and create ticking . Just give the chains a good visual inspection,they are pretty beefy. If you dont hear any chattering or slop in the engine ,the tensioners are probably fine.
But if you got the money ,replace that stuff if you can.
Just count your valve cover bolts to determine if the cam gears are pressed. 11 = Romeo and bolt on gears.
13/14 = Windsor and pressed on gears.
marktuck99
