Can someone help me with my egr delete?
Discussion in '94-95 5.0 - Specific' started by Siik Chipmunkz, Mar 25, 2015.
  1. Siik Chipmunkz
    Siik Chipmunkz New Member
    16
    Oct 24, 2013
    West Virginia
    Plan on deleting my egr and all the block off plates are for foxes or modulars, does the fox block off work for the sn95 5.0? (Factory Intake)
  2. lutter94
    lutter94 Well-Known Member
    3,023
    139
    Apr 11, 2008
    South Dakota/Iowa
    I made my own with some scrap steel at work. I know there are a lot of different options, they're not all the same.
  3. mcglsr2
    mcglsr2 Well-Known Member SN95 Supporter
    3,410
    25
    Jul 4, 2011
    Orlando
    I'm not sure either if the Fox block off plate will work on a SN95 5.0 - I do know the throttle bodies are different (specific to 94 & 95 5.0). Also the EGR valves are different parts for the 94 & 95. So a Fox block off plate *may* work but will most likely require some modification - I don't know if it's a direct bolt-on.
    Your best bet, IMO, is to do what lutter94 did and just make your own. If you have a piece of steel or thick-enough aluminum lying around, just cut it up, drill the bolt holes and slap it on there. If you use aluminum, just make sure it's thick enough that it won't bend when you are installing it and create a gap. Done and done.
  4. CC'S95GT
    CC'S95GT Post Whore
    10,738
    172
    Apr 19, 2008
    What are you planning on doing about the CEL?
  5. Tony Corley
    Tony Corley New Member
    68
    Mar 17, 2015
    Fox is different. There are several 94-95 specific on Ebay for under $10, or like stated, you can make your own out of a piece of flat stock.
  6. SNorange94
    SNorange94 Member
    115
    Mar 12, 2014
    Dingmans ferry, PA
  7. lutter94
    3,023
    139
    Apr 11, 2008
    South Dakota/Iowa
    I had the emission codes removed with a SCT chip, worked great.
  8. 95opal
    95opal Well-Known Member
    2,040
    207
    Jun 21, 2007
    351 fuel pump block off plate and turn the egr function off in your tune.
  9. JKady
    JKady Active Member
    266
    Mar 20, 2013
    Graham, WA
    Cut the flange off your egr valve and mount it opposite of the way it was originally, it'll block the hole in the intake and it's FREE. I did mine in about 5 minutes minus the time for the paint to dry.
