1996gt
Livernois Motorsports 298 Cubic Inch Street Series Stroker Short Block – $3,999.99
- Production Iron Block
- Custom Livernois Forged Steel Stroker Crankshaft
- Exclusive Livernois/Mahle Pistons, Rings, Locks, and Wrist Pins
- Exclusive Livernois/Manley H-Beam Forged Connecting Rods with ARP2000 bolts
- Clevite Tri Armor Engine Bearings
- Limited One Year Warranty
- Rated to 1,000 Horsepower
9.6-1 compression ratio
I. Rotating Assembly : Professionally built by Livernois Motorsports, all fasteners torqued to specs and marked. Engine has never been started.
1. 2003 seasoned cobra block, bored 20 thousand’s over.
17cc dished pistions-maybe
2. Snyder stroker forged crank.
3. Manley forged Rods.
4. Mahle phosphate coated pistons.
5. Stainless steel valves.
6. Livernois custom grind stage III blower cam.
7. Ford PI heads with Livernois stage III port and upgraded springs.
· 5 axis CNC machined
· Fully assembled w/o camshafts
· Intake flow rate 225 CFM
· Exhaust flow rate 205 CFM
· Custom valve job
· Custom ground stainless 1mm oversize (45.5mm) intake valves
· Custom ground stainless 1mm oversize (37mm) exhaust valves
· Bronze guides
· Ford valve seals, retainers, and locks
· Livernois exclusive single coil valve springs good to ~ .600 Lift
8. ARP fasteners.
II. Induction :
1. Fox Lake P 51 intake.
2. Accufab 75mm throttle body, (polished).
3. Paxton Novi 1000RR centrifugal supercharger (polished).
4. Reichard Racing 2 ½ “ supercharger pulley (chrome plated).
5. Supercharger brackets (powder coated white).
6. Inlet Tube, custom fabricated 4” aluminum (powder coated white).
7. Discharge tube, 3 ½” (powder coated white) modified to accept SCT BA 3000 mass air meter sampling tube (modified for blow through metering)
III. Fuel Delivery:
1. Stock Ford tank modified to accept braided feed and return fuel lines.
2. Gas tank strap (chrome plated), tank painted black.
3. Braided fuel lines feed and return with Aeroquip fittings.
4. Billet Aluminum in line fuel filters with replaceable screens).
5. Ford in tank 255 lph fuel pump
6. Kenne Bell boost a pump with controls mounted in console.
7. Pro M adjustable billet fuel pressure regulator.
8. Fuel pressure gauge mounted on regulator and gauge in A pillar.
9. Pro M fuel rails.
10. 62 pound injectors
11. Snow water methanol injection with Canton custom fabricated chrome plated
Coolant reservoir.
12. 4 gallons of Snow coolant mix.
IV. Cooling and Lubrication:
1. Fluidyne aluminum radiator.
2. Water inlet neck (chrome plated).
3. Radiator hose, flex steel and chromed.
4. Canton, radiator overflow reservoir (chrome plated).
5. Moroso 7qt. oil pan.
6. New Ford high output oil pump.
7. Oil dip stick tube (chrome plated).
8. New water pump (pulley is chrome plated).
V. Ignition:
1. MSD coil packs (mounted in custom location).
2. TRW spark plugs, one (1) setting colder.
3. Taylor 10.5mm plug wires (custom routing).
VI. Exhaust:
1. Pro M 1 5/8” headers, ceramic copper coated inside and out, 2 ½” pro chamber. Coating by Jet Hot.
VII. Engine Accessories
1. Power steering pump, new, (brackets powder coated white)(pump pulley chrome plated).
2. Canton power steering fluid reservoir (chrome plated).
3. New alternator (case powder coated white) (pulley chrome plated).
4. Pro M harmonic balancer.
VIII. Other:
1. Valve covers, original phenolic plastic (chrome plated).
2. Front engine cover (powder coated silver).
3. All wiring in custom braided loom.
4. Vacuum hose, all silicone, red or blue.
5. Radiator cover, real carbon fiber.
6. Upper fire wall trim piece, custom carbon fiber.
7. Windshield cowling, custom carbon fiber.
8. Hood hinges (chrome plated).
9. Breaks master cylinder (chrome plated).
10. New Optima red top battery.
TRANSMISSON
I. Ford 4R70W, complete rebuild with Baumann Engineering upgrades
Precision Industries 3200rpm stall converter.
II. Drive train:
1. Custom fabricated aluminum driveshaft.
2. T.A. differential cover.
3. Stock 28 spline axels.
4. Ford, 3:73 gears.
5. Transmission cooler (heat exchanger damaged, needs replacing).
6. UPR transmission shift lever (powder coated white).
7. Transmission dip stick tube (chrome plated).
INTERIOR
I. Upholstery:
1. Seats, custom vinyl with white look carbon fiber inserts and embroidered mustang beneath head rest.
2. New Ford Racing floor mats.
3. New upgraded interior carpeting.
4. Rear seat deleted (in anticipation of stereo installation).
II. Interior Gauges: In construction….
1. White face gauge overlay to match reverse el glow gauges.
2. Twelve aftermarket gauges, nine are reverse el glow, three are Dakota digital amplifier temperature gauges, heat sensors are already run to the rear of car for attachment to the amplifiers.
3. Triple A pillar pod.
5. Custom fabricated center gauge cluster with hidden l.e.d. lighting.
6. Remote radar detector with front and back laser protection.
SUSPENSION
I. Rear Suspension:
1. TA differential cover.
2. Maximum Motorsports pan hard bar. Brackets (powder coated yellow), bar (chrome plated).
3. Steeda progressive rate rear springs.
4. Rear sway bar with new polyurethane bushings (powder coated yellow).
5. Maximum Motorsports full length sub frame connectors (powder coated yellow).
6. Maximum Motorsports torque arm (powder coated yellow).
7. Maximum Motorsports lower control arms (powder coated yellow). Note: upper control arms are deleted with the torque arm to prevent binding and allow for full rear suspension travel.
II. Front Suspension:
1. UPR tubular K member (powder coated yellow).
2. UPR tubular A arms (powder coated yellow).
3. UPR Coil over conversion (springs powder coated yellow).
4. Steeda x ball links.
5. Steeda billet aluminum front sway bar bracket with new polyurethane bushings.
6. Front sway bar (powder coated yellow).
7. Steeda adjustable bump steer.
8. Maximum Motorsports steering shaft.
9. New polyurethane end links.
10. Maximum Motorsports aluminum steering shaft bushing, not offset.
11. Shocks and struts, Illumina 5 way adjustable.
III. Front Brakes:
1. Ford cobra two piston PBR with EBC yellow stuff pads (new).
2. Baer 13” slotted and cross drilled rotor (hat painted red).
3. New braided lines.
IV. Rear Brakes:
1. Ford single piston (caliper painted red) with EBC yellow stuff pads (new).
2. Baer 13” rear rotor (hat painted red).
BODY
1. OEM cobra body kit.
3. Saleen rear spoiler.
4. Hood, cobra 2000R functional cowl, painted.
5. Roof scoop, damaged, replace is brand new.
8. New interior fender liners, painted black.
9. Engine bay has been smoothed and painted.
10. Shaved door handles.
STEREO
1. Head Unit, alpine
2. Front Speakers, Audiobahn component, 6 ½” midrange, 4” midrange, 25mm tweeter.
3. Rear Speakers, Audiobahn 5 ¼” midrange for fill.
four channel amp, with custom clear acrylic bottom.
6. EQ, Audiobahn 30 band 1/3 octave with bass boost and line driver.
7. Other component parts, I will have to take out of storage, will be available during parts inventory.
