Casper the Cobra - Procharged 96' Cobra
I know the modulars have a different fill/burp method than the 302s but can one of these help?
Venompower
Venompower
Batavia, IL
That is awesome! Since we fill at the coolant crossover, I have to deal with trying to not spill, and trying to get the system burped of all air since the crossover is higher than the radiator and reservoir.
The shop doing the exhaust is going to vacuum fill the last bit of coolant today, but I'm still going to buy one of these for the future.
the zero spill funnel should be perfect as long as the fittings fit and it comes with more than a few. You just fill it up and start the car and as it runs the air goes out and it keeps filling. When your done you close the valve at the bottom and take it off and its full.
joemomma
Car is looking good! I have the 555G2 on mine, and they seem to hook well at my stockish power levels.
joe65
Dude, like the wheels and new rubber.!! did you get the coolant burped? Curious about your experience. I heard an idea that someone had once of just elevating the front of the car enough that the air finds its way to the top where it needs to release...the overflow tank. Not sure if that's a valid way to do it. So I'm curious.
Venompower
Venompower
Batavia, IL
Thanks! I actually had a shop vac the system to remove the last bit of air. You are right about the process but I was having difficulty, as my coolant was up to the bottom the of the reservoir but even with the front raised, there was coolant in the cross over. Ended up adding about a gallon, even though it didn’t seem that low. I’ll try the vac fill thing that was posted but if I ever had issues again I would gladly pay to have a shop do it.
Venompower
Venompower
Batavia, IL
Had a pretty good birthday, wife got me a Procharger license plate holder and a suction mount for my GoPro.
I still need to change the fuel filter but haven’t made it a priority because as soon as the weekend ended the weather here got crappy again. I also placed an order with LMR for an SCT X4 so I can data log.
Venompower
Venompower
Batavia, IL
Took a break to play Mr. Mom this week as our sitter had surgery… got a bunch of parts Ill post tonight. Quick question though how much R-134 do our cars take when empty, and can they be recharged without jumping the low pressure switch?
joe65
Good question. on my end i just plug the bottle in with the gauge and fill until its in the zone on the dial indicator. Happy B lated!
Venompower
Venompower
Batavia, IL
Thanks man, i have always done it that way but some internet mechanic said the compressor needs to be running and the switch prevents that when empty…
RAU03MACH
NEW MEXICO
the way i do it if empty after recovery and vac test , on the air dryer canister pressure switch jump the pressure switch plug in wile running ,that way the Freon is instantly entering the system
Venompower
Venompower
Batavia, IL
How much does our system take if empty?
RAU03MACH
NEW MEXICO
they help a little , but its a mess maker , while im filling up the cooling system on mine ill squeeze the hoses to get the air out
RAU03MACH
NEW MEXICO
Ford MUSTANG Refrigerant Capacity and Refrigerant Oil Type​
2018 4 Cyl. 2.3 Eng. – 19.20 Oz. R-1234yf; 4.00 Oz. PAG Oil
4 Cyl. 2.3 Eng. – 3.40 Oz. PAG-46; See Under Hood Decal
8 Cyl. 5.0 Eng. – 19.20 Oz. R-1234yf; 4.00 Oz. PAG Oil
8 Cyl. 5.2 Eng. – 24.00 Oz. R-1234yf; 4.00 Oz. PAG Oil
2017-15 4 Cyl. 2.3 Eng. – 4.00 Oz. PAG-46; 20.80 Oz. R-134a
6 Cyl. 3.7 Eng. – 4.00 Oz. PAG-46; 20.80 Oz. R-134a
8 Cyl. 5.0 Eng. – 24.00 Oz. R-134a; 4.00 Oz. PAG-46
8 Cyl. 5.2 Eng. – 24.00 Oz. R-134a; 4.00 Oz. PAG-46
2014 6 Cyl. 3.7 Eng. – 4.00 Oz. PAG-46; 21.12 Oz. R-134a
8 Cyl. 5.0 Eng. – 4.00 Oz. PAG-46; 21.12 Oz. R-134a
8 Cyl. 5.8 Eng. – 4.00 Oz. PAG-46; 21.12 Oz. R-134a
2013 6 Cyl. 3.7 Eng. – 21.00 Oz. R-134a; 4.00 Oz. PAG-46
8 Cyl. 5.0 Eng. – 21.00 Oz. R-134a; 4.00 Oz. PAG-46
8 Cyl. 5.8 Eng. – 21.00 Oz. R-134a; 4.00 Oz. PAG-46
2012-11 6 Cyl. 3.7 Eng. – 21.00 Oz. R-134a; 4.00 Oz. PAG-46
8 Cyl. 5.4 Eng. – 21.00 Oz. R-134a; 4.00 Oz. PAG-46
2010 6 Cyl. 4.0 Eng. – 21.00 Oz. R-134a; 4.00 Oz. PAG-46
8 Cyl. 4.6 Eng. – 21.00 Oz. R-134a; 4.00 Oz. PAG-46
2009 6 Cyl. 4.0 Eng. – 26.00 Oz. R-134a; 7.00 Oz. PAG-46
8 Cyl. 4.6 Eng. – 26.00 Oz. R-134a; 7.00 Oz. PAG-46
8 Cyl. 5.4 Eng. – 26.00 Oz. R-134a; 7.00 Oz. PAG-46
2008-07 All Eng. – 26.00 Oz. R-134a; 7.00 Oz. PAG-46
2006-05 All Eng. – 31.00 Oz. R-134a; 7.00 Oz. PAG-46
2004-97 All Eng. – 8.50 Oz. PAG-46; 34.00 Oz. R-134a
1996-94 All Eng. – 7.00 Oz. PAG-46; 34.00 Oz. R-134a
Venompower
Venompower
Batavia, IL
A little confused by the list… different amounts between 94-96 all engines and 8 cylinder 4.6?
rvseverson
Staff online
