DKblue98GT
- Joined
- Dec 19, 2009
- Messages
- 1,406
- Reaction score
- 333
Nice that you were able to fix the clutch issue.
Sent from my VK815 using Tapatalk
You have no idea... that was kind of the elephant in the room. Can I get the car driving with clutch cable adjustment, or is the pressure plate incorrectly torqued, transmission bad, etc.Nice that you were able to fix the clutch issue.
are you sure about this? I mean it seems to me if it were absolutely wrong you would know for sure and that does not sound like the case here so for the sake of stirring the pot I vote you get it. Anyone second that?
Good deal. love it when it is just a timely fix and not a big $ mod needed.!Hope everyone had a good Easter, the weather here was absolutely phenomenal, 75 and sunny. Did Easter baskets and egg hunt for the kids in the morning, then went for a long walk, and sat on the deck doing some day drinking... which led to me telling myself to not be lazy and get something accomplished on Casper.
When I purchased the car the previous owner told me that the vehicle didn't shift. He claimed that a transmission shop told him he needed new synchros. The car has a TKO600, and it seemed unlikely to me that the synchros were trashed. The local club agreed, that the transmission was probably fine and suggested it could be a throw-out bearing seized to the input shaft. Upon deeper inspection I found the firewall adjustor was installed backwards. I checked under the car and the clutch cable was tightened at the very end. I had a hunch this was the problem.
Today I finally uninstalled the cable and reinstalled it correctly. I found that instead of the second nut being tightened against the first to lock it, one was installed on each side of the clutch fork... I used a prybar and tightened the cable to the half way point on the threaded end and fired it up, moment of truth. When I was able to shift into reverse with the engine on, I had a very good feeling. After driving it down the street and back effortlessly shifting through gears I was overjoyed.
We will ignore the fact that I forgot to plug in the passenger side coil, and was running on 4-cylinders lol. That was immediately corrected once I returned home. I'm still having an idle issue after cleaning the IAC, it know idles right around 1,000 rpm but every now and then it dips and almost stalls then goes back to normal. It's not the throttle body as I put a temporary rubber plug in the top hole. I did go ahead an order a new IAC as it appears cleaning is a band aide, others have reported similar in different threads. I should be receiving the T-Bolt clamps I ordered and can finally get the intake installed correctly.
Man look at all that grey hair in the last picture... I need a vacation to a beach!
I definitely took the possibility of needing a transmission into account when I bought Casper. I also picked up the stock transmission which was said to be in working order as part of the deal.Man I am jealous to say the least. I never have simple solution fixes for the problems I inherit. With that being said I am glad you have a smooth shifting transmission without having to fork out $$$ to fix that.
Seeing your post is motivating myself to finish mine this Spring.
My motivation goes up and down depending on the weather, my kids, etc. I always like wrenching with friends/family, so solo wrenching takes some effort. However, I would encourage you to break down what your car needs into a to do list and start hitting it one at a time. I'm about to buy a dry erase board for this, because knocking stuff off my list keeps me going.
Oh and update, for every thing I finish I seem to find something new. Car has no catalytic converters, and long tub headers to flowmasters... car is quiet... I think a previous owner had the flowmasters installed backwards. I will be dropping the exhaust tonight to confirm... shakes head...
I have an app on my post it note on my laptop that I use to keep my lists and yea it helps a lot. Some night I just make a list of the next 3-4 things I want to get done and it is satisfying to mark them off the list and then look to what is next.
I get the whole kids ,weather ,sporting events, work, etc. my list could go on for days. I have a list, just have not been good at getting to it. I have a build thread going but haven't had anything worth updating atm. HOWEVER....I should be getting my long tubes and x-pipe in this week. So hopefully I can motivate myself to finish my current task of rebuilding the engine.
You could try what I doYeah last night I knew I wanted to get the exhaust removed, but then I was like... it's been a long day, then cooking dinner, family walk, bath time and bedtimes routines for my boys, by the time I could go down to the garage I just want to sit on the couch and relax for a bit.
Tonight though I'm going to try and force myself to get this done. Get the car jacked up enough to confirm orientation and hopefully model number and then go from there.
BBK Off-road H PipeJust a question for myself to ponder but do you have a O/R X or H pipe?
44 are usually louder deeper black with dimond caseWell the mufflers are in the correct direction, neither side is stamped inlet, but it has the Flowmaster stamp and the patent numbers. The serial number is also stamped on the inlet side, which I have read is normally stamped on the outlet side?? I could see the weld marks for the V shaped defelctors and they also confirmed correct direction.
Anybody have theories on why they don't sound like Super 44 mufflers (which the serial confirmed)? I'll try to get a video today, though I now likely have an exhaust leak at the mid-pipe to catback connector.
BBK Off-road H Pipe
They have to be very old versions, I'm tempted to buy a new set of Original 40 Series and have then welded in place of these and then go from there.This is just my opinion but I feel like the mufflers may not be 44's or they may be older ones.
If your looking for loud just slap some SLP Loudmouth mufflers on it.
I had stock manifolds, O/R Bassani X-Pipe and a Bassani Cat-Back with exhaust tip resonators on my car before its rebuild and it wasn't "loud" at idle but with spirited driving it was plenty loud for 95% of people.
