Catch Can Locations
97stanger
Just looking to see if those of you running catch can/breather setups can post pics of locations where you have yours mounted? Just trying to get some ideas. Thanks in advance.
Im strapped for space with a 5.4l hogging it all, but I used an air line moisture catch "can" from any hardware store. Its small capacity, but works great, just empty it more. However, I did machine the nipples to accept 3/8 hose
hotmustang95
Boynton Beach FL
Put mine on the pass side firewall. I once had a little issue as you can clearly see. All good now but I still left the can there anyways. This is a cheap one off Ebay. They come in many colors.
97stanger
97stanger
I actually already have this UPR breather tank:
http://www.uprproducts.com/billet-breather-tank.html
It's pretty large, and 03DSGGT has helped me a bunch in the past with his write-ups on putting it behind the reinforcement bar, but this thing is pretty large and if I can't put it in the existing area where my driver side coil pack is now than I may have to try to find somewhere under one of the fenders
03DSGGT
SN95 Supporting Member
Akron, Ohio
Your UPR piece looks to be about the same size as my Moroso can, and if I remember correctly mine is about 11" with the breather installed.
97stanger
97stanger
Yup, thats pretty close to the exact size as mine
03DSGGT
Akron, Ohio
That should fit nicely in the fender area if you don't have anything in that area already
97stanger
97stanger
I'll have to try the passenger fender, I have a pretty big trans cooler stuffed under my driver's
03DSGGT
Akron, Ohio
OK, well if you need pics or have any questions let me know and I'll do what I can to help ya out...
kb1982
Kentucky
I have a moroso bolted to the passenger side strut tower, but mine is a 5.o. Dont know if the mod motors have much room left in that area. Only drawback is when I empty it, I have to unclamp it from the bracket (1 bolt) or else it would run down on the headers.
castine917
wyoming, mi
My 95 with a 5.0 is mounted to "framerail" under the intake. Puts the catch can drain in an open spot near the radiator drain.
rvseverson
