Well as the title states I changed the front calipers, brake pads and rotors to the ones found on Cobras and wow great upgrade. However, I have came across this odd noise coming from what sounds like the drivers side wheel well. The best way I can describe the noise is a whoosh whoosh whoosh sound with each whoosh representing a 360 degree turn of the tire. The sound is very light and high pitched and doesn't sound like pads grinding on the rotor. I can only hear it up to about 30 mph and then I can't hear it anymore and the sound isn't always there (which makes me think it's not a warped rotor) and I don't hear it when I'm using the brakes.
I have also came across this slight metal to metal chatter when I hit a bump in the road. Also sounds like it's coming from the front wheel well as well, but I can't be for sure. Can't say that I hear the chatter when braking and simultaneously going over cracks or bumps in the road. I'm thinking it's possible that these two noises are associated but I have no idea. I also thought the dust shield might have been bent during the install so I'll double check it when I take the wheel off on Wednesday.
Any other suggestions? Things to double check?
