clatter,clatter
potty
Michigan
Hello all,
I recently pulled my engine 94 coupe 5.0. Last year I ran stock internal with "p" heads and really no other mods motor ran great and quite. So this winter I added exp intake e cam and TFS stage one springs and all you can hear is lifters oil gauge is at better than half way on normal. Any advice please.
Addermk2
Did you replace your lifters?
Did you soak them in oil before installing them?
Did you check for proper pushrod length?
Did you shim your rockers?
Did you verify the correct installed height of your valve springs?
I could go on... But ill let you catch up first.
SLOW95GTS
Roller rockers are probably hitting the valve covers...
99GreenStang
i agree with addermk2 if you changed heads you need to measure rod length .
G_94_T
TN
I don't see where he changed his heads. Intake, cam, valvesprings......
Addermk2
Hello all,
It's there.
bs.austin.tx
