07GtS197
Im leaning towards the master cylinder failing or the cup seals. The hydroboost should be ok because when they go bad the pedal gets really stiff. Im going to keep on bleeding and see what happens. Since the caliper is still sticking and the drivers side front is closest to the master cylinder Im thinking thats what it is. It would make sense if the cup seals are going because brake fluid will get past the seals causing the brakes to go to the floor and then when you let off, the brake fluid needs to move the other way past the cup seals which creates a temporary vacuum effect and temporarily keeping the brakes applied. We will see.
