Mustanger
over on the Mach 1 Registry there is a guy sell a 13" Baer Eradispeed Mach 1 front brakes & SS lines for $400 shipped...only 5000 miles on them. look great, drilled & slotted!
are you still using the stock GT master cyl?bybyz06 said:For anyone who has done the Cobra upgrade, have you noticed your brake pedal feel is much stiffer than before? I'm wondering if it's because of the steel braided lines and it's causing increased pressure at the pedal...
Mine was "stiffer" before braided lines. Its the Cobra master cylinder.bybyz06 said:For anyone who has done the Cobra upgrade, have you noticed your brake pedal feel is much stiffer than before? I'm wondering if it's because of the steel braided lines and it's causing increased pressure at the pedal...
scarface said:are you still using the stock GT master cyl?bybyz06 said:For anyone who has done the Cobra upgrade, have you noticed your brake pedal feel is much stiffer than before? I'm wondering if it's because of the steel braided lines and it's causing increased pressure at the pedal...
scarface said:braided lines should decrease brake pedal effort, maybe feeling "harder" is that.
