control arms
Discussion in '94-95 5.0 - Specific' started by 94 DropTop, Jul 25, 2007.
  1. 94 DropTop
    94 DropTop Well-Known Member
    2,987
    Jan 3, 2007
    a guy i work with says that i can just take my rear control arms and box them in for alot cheaper than new control arms. Is this true? would it give me about the same performance as buying new ones? what is the difference between some say upr control arms and stock? besides one is tubular and one is a c shape? thanks for the help.
  2. Passenger
    Passenger Well-Known Member
    1,391
    May 1, 2007
    Material used would differ as well. With my little accident I had last week, if I had stocker Lowers I'm sure they would have bent. But my UPR chromoly lowers are still straight as can be.
  3. CanaryGT
    CanaryGT Well-Known Member
    3,688
    May 22, 2006
    Phoenix
    Dude... I got the MM LCA and it did WONDERS for the car.. buy it.... and use it.... you will be happy!
  4. 94 DropTop
    2,987
    Jan 3, 2007
    so besides the material. wouldnt the concept my friend stated work just like boxed control arms?
  5. TripleBlack
    TripleBlack New Member
    72
    Jan 22, 2007
    they still wouldn't be as strong aftermaket xontrols arms are thicker metal and you would want to get the poly bushings so it would be easier/better to get the aftermaket.....
  6. ranger50toy
    ranger50toy New Member
    82
    May 3, 2007
    Have you seen the rubber bushings that the stock arms come with? They are probably shot by age alone.
  7. ryclef331
    ryclef331 Well-Known Member
    2,913
    Jan 20, 2006
    There is SO much deflection in a stock rubber bushing that its not even WORTH the time to box'em. You buy the box kit, then pay to have someone weld it....you still have crap bushings. For probably another 60 bucks, you can have an entirely NEW stronger arm. Don't cheap out....swap'em out for some UPRs....and give your friend the stockers so HE can box'em.
  8. 94 DropTop
    2,987
    Jan 3, 2007
    i guess ill get them then.
  9. samseed101
    samseed101 New Member
    19
    Jan 27, 2007
  10. CanaryGT
    3,688
    May 22, 2006
    Phoenix
    :nonono:
    Im trying to tell you guys that the MM ones are the best.... They have great quality and I can speak from experience that they are effective....
  11. stang94X
    stang94X Active Member
    720
    May 16, 2007
    Lakewood all the way :thumb:
  12. 94 DropTop
    2,987
    Jan 3, 2007
    i already both the ones with sub frames. hopfully those will drop my 1/4 time alot. i will also be adding a new set of tires.
