I have read converting to Foxbody throttle cable helps a ton for throttle response in SN95 cars. Is there any truth to this? I would like to do it to my 94 GT, but if the results are only mediocre I don't think I'll waste my time. Anyone know for sure?
Just a fox throttle cable? No. The fox upper with t/b on a SN, stock for stock, also no. Don't waste your time.
So there aren't really any upgrades for throttle response, are there. Go ahead and say it, a new high performance built engine lol
I did it cuz it looks better.. but main reason was to get a 90mm tb on there. you have more options. not going to find a good tb with that elbow there.
Do the swap dude. That way you'll have a whole lot more options as far as throttlebody goes. 94 and 95 models are limited to 75mm max size. I've done the swap and i am using an Accufab 90mm on mine. You will need fox body throttle cable and bracket, check Lokar if u can't find one. you might have to delete your EGR and use a 3/8 spacer, i got mine from Accufab, u need the spacer cause it has the bolt holes for throttle bracket to bolt to, Accufab makes two different sizes- 2 inch and 3/8 inch. I used 3/8 because it gave me more room for supercharger piping. NOTE- cruise cable will not work unless u can change the cable to fox body cable. No difference in throttle response just more to choose from.
Your old 94/95 throttle cable may have excess slack in it, buying a new OEM cable may help with throttle response. As far as being able to run a larger throttle body than a 75mm, it isn't needed unless you have a race car.
I have a fox cobra intake on my 95. change over the throttle cable and everything works fine. as far as throttle response, it's a minuscule difference if any at all.
