Hey guys, So, I recently bought my '97 GT and I need to get it smogged. Everything should be in order except for one issue: There's an MIL code throwing a check engine light that pertains to my coolant temperature sensor. The thing is...which one do I replace? I know there are two sensors on a 4.6 V8 (One for the instrument cluster, and the other for the ECM), but I'm not sure which sensor is faulty and could be throwing the code. I've already tried replacing the one next to the intake a couple of times, and that doesn't seem to have fixed anything so far. The wires don't appear to be damaged either. Any ideas which sensor I should be looking at replacing? The left side, next to the alternator? Or the right side, in front of the intake hose? Thanks guys.
now that I think about it though I had mine disconnected for a long time and all it did was kill the dash gauge, never had a light. I don't think it reads to the computer at all so I would guess its the one not going to the dash.
This article helped me fix the problems I had when I swapped a 32v into my 98 gt. Don't worry about the "3.8l" part of it. The sensor troubleshooting part of it will still work. http://troubleshootmyvehicle.com/ford/3.0L-3.8L/how-to-test-the-coolant-temp-sensor-1
Yeah, I used that troubleshooting thread before to try to figure it out...As long as both sensors are in the same place on the engine it shouldn't make a difference. I'm starting to think that from the "wiggle" test it's probably the wiring harness, so I'm likely to go from there...I'm not 100% sure yet though.
So, having officially attempted to place the new sensor in BOTH of the ports (just to figure out which is which), my only logical conclusion is that it is in fact one of the wiring harnesses. I did a voltage test of one of the sensor wires recently as well and it seemed to be producing lower than normal voltage, so that's likely my problem... The only other thing I found curious was that the new sensor had a bit of trouble going into the thread in both ports, despite being the correct verified part number. I have the aluminum crossover on my intake header so maybe that might have something to do with it? Anyone know anything about this?
