Cooling fan/ fans
96laseredcobra
Farmington MO
Alright fellas having cooling issues. Problem is ,I have a v2 supercharged 347 out of a fox body. Utilizing pass side fox pulleys plus crank, drivers side sn95 pulleys. OEM fan wont fit , so I'm looking for options on duel setups and any help will be greatly appreciated. instasize_210410224500.jpg
Sent from my SM-A102U using Tapatalk
I have the same vortech and had the same problem hitting the supercharger pulley. I couldn't see any systems that looked significantly thinner so I ended up moving the condenser and the rad up closer in the core support and went with a mishimoto fan/shroud that was just a little thinner than the stocker.
where did ya get that hard, bent coolant hose in the middle? I need one of them... Yours looks like there is more space than I had. Any chance if you just modify the upper rad mounts to pull it in a little bit that it would fit? Not sure what the timeline is as it might take a few days to get the parts in you hope fit or a couple of hours to modify what you have.
96laseredcobra
96laseredcobra
Farmington MO
No time limits but death lol. I actually just reversed fan polarity and so far so good. Will need another small 7 inch fan for low speed .
why would you want the fan to run backwards? I saw the wires you have going between it and was hoping that was not going to stay that way?
96laseredcobra
96laseredcobra
Farmington MO
It was not cooling . So I put it back how it was . Ordered a 7 inch for low speed. Hopefully itll be ok . It was hooked up backwards I'm guessing
I want to make sure we are talking about the same thing, you intentionally wired the fan backwards because it was not cooling when running forwards?
96laseredcobra
96laseredcobra
Farmington MO
Someone reversed it and I didn't know. Working now
Subtlebeast
Central NJ
I am running a sn95 fan and the wiring is reversed so the fan can be used as a pusher in front of the radiator. I haven’t had any issues with it. I am running a YSi fox body set up with a 10 rib.
jarthur1995
