Hi all, first post. I have a 1996 Mustang 3.8 that I've driven for close to 10 years now. the heat used to work, but now does not (I'm not sure when it stopped working, living in FL I don't use it much at all).
I got a P0125 code the other day which was a first for me, so I set off on trying to track the issue down. I checked my coolant level, and everything was nice and topped off. my thermostat opens after a couple minutes of idling, which is visible on the dash gauge (it drops a bit from "R" to "O" on NORMAL.) however, according to my OBD2 reader, the ECT is only reporting a range of 140-160 degrees F. and it takes a LONG time to get there, close to 10-20 minutes of running.
I tried turning my AC off (its always on) and the fan never comes on by itself, even when it was threatening to overheat (boiling coolant and gauge at M/A). Turning the AC on makes the fan come on again and it normalizes.
I borrowed an IR thermometer and the temp by the thermostat was in the 200 range.
now for some stuff I did.
as a just in case fix, I went ahead and changed the thermostat out with a new one (both 195 degree) and also changed the ECT sensor with a new one in case it was reading low and faulty. the new one behaves exactly the same. I did notice quite a bit of debris and gunk in the piping under the ECT sensor, which i cleaned out with my finger as best I could - and my coolant appears to be fairly rust colored when I was burping with my funnel.
no matter what I do, I don't have heat and the ECT won't read higher than 170 (after an hour idling) maximum, so the fan never comes on and I imagine its impacting my fuel ratio as well.
the heater core hoses seem equally hot.
could this be something as simple as some clogged passageways, or do I have a bigger issue occurring? anyone battled something like this before?
