ok so I went out tonight with some friends and now I fuckin regret it! I had to leave my stang at some side of street downtown, I pray no one fucks with it :noes:.....it wouldnt start, we tried pushin it reverse then forward to jump start it, then we tried with some cables and nothing, what could it be ? alternator ? and if it is how hard is it to install a new one ? is it true u just disconnect like 2 cables n vice versa with the new one ? or will i have to have it towed to my house ???? PLEASE HELP, THIS BLOWS!!!!!!!!!!!!!!!! :help2:
Re: could it be alternator ??? so since I dont know what it could be, u think my best bet would be to have it towed to my place and then try to figure out what it is n fix it here, I just want it to be safe. hope no one fucked with it.
Re: could it be alternator ??? well I jus called my bro in law and he said it cant be alternator or starter cause if it was, by pushin it and tryin to jump start it that way it would of have. he said somethin bout maybe bein the cylenoid/s whatever that is. anyways this sucks.
well I just got home from towin my car, they charged me $132.50 I am just happy my baby is SAFE and HOME!!!!!!! now to figure what is wrong with her and get her back on the road ASAP!!!!! :banana:
when I turn the key it jus makes a noise for like 1 second and nothing but no tryin to start up, the guys said it might be fuel pump. who knows tho, im gonna go look at it in a bit. they also said wires to alternator or maybe battery might be loose.
when you turn the key, see if the interior lights cut off and the warning lights in the gauge cluster cut out. If so your battery is dead. You will need to get a new one or a charged one to even see if the alternator is charging.
sounds like it is the battery. If the fuel pump was bad it would still crank over. The fuel pump wont work if it dont get any juice
or he dont know how to pull start properly :dunno: if it was just the starter then it would start by pushing but if it has no juice then how is the fuel pump etc going to work?
if the battery is completely dead, he would have had to leave the cables on for a long time to even get it to try and turn over. Its a computer controlled car. the ECU needs a certain amount of voltage to operate...if it isnt there, the car isnt going to start.
before you tow it, just try someones battery in it, just needs a top post battery. you could be spending a ton on towing, when it is a 50 dollar battery.
I just went outside, and yea. I turn the key and no noise at all whatsoever. one more thing u kno that lil lever u can pull on to make the engine rev, i pull on the lil silver wire and then let it go n it feels like there is a lil ball connected at end when it drops, is it suppose to do that ? so if the battery is dead as in dead for good it wont start even if I try to jump it ?
if ya have a battery you can swap out try that. Or just put a charger on the battery for a little while. also might want to wiggle the battery cables and make sure the cables are on the posts good
