This thread needs a Coyote update
Where to start?
Interior:
I purchased a 6 point roll cage during the winter, it will have removable side bars. Having it professionally installed and welded in by fabricator that works on drag cars. Going back to the stock shifter (See transmission update below). I removed and sold the aftermarket black carpet I’ve had for 10 years. I’m replacing it with stock carpet from my 97 Tbird parts car. Going to have it cleaned and dyed black. Replacing the stock seats, yet again with a pair of Sportline RRS Corbeau Racings seats with 5 point harness. This time I won’t be using their brackets. I have a pair of MN12 manual seat brackets that I will modify to work.
Suspension and Chassis:
Just installed rear aluminum subframe bushings, beefy rear diff mount and LWP cover. Waiting on new QA1 coil over shocks front and rear. Dropped the AJE K-member one inch because the Supercharger was slightly touching the hood. This will also help with the transmission clearance as well.
Wheels:
Over the winter I had my front wheels narrowed 1.5” to help with the rubbing issue with the strut bar.
Fuel system:
I recently bought an Aeromotive 15 gallon fuel cell, new PFTE lines, fittings, fuel filter and fuel rails
Engine / Trans management:
So I ditched the FRPP Coyote control kit for Power by the hour’s engine/trans control kit for the Coyote 5.0 and the 6R80 auto. This works all together on the same computer instead of using two standalone units to control each. The transmission will also have a sport mode to shift threw all the gears manually with a touch of a button.
Transmission:
Picked up a 6R80 from a 2014 F150 with just over 5K miles. With a one inch drop from the K-member I hope this will fit in the trans tunnel. I will be able to use the MN12 stock shifter and cable with a 4R70W lever adapter. I’m hoping with a custom 6R80 mount, it will work with the MN12 cross trans brace.
Anyways just waiting on parts. Between family, work, house projects and everything else I might do a 3rd shift again to finish this for summer.
