Coyote Swap new edge fuel issue
DDautodetailing
Hey guys . So I’m working on a coyote swap for my vehicle and having a fuel issue. Car does not want to start but cranks . Shows fuel pressure. Injectors seem to be good I put a meter on it and they were all within spec. However when time to crank I am getting no injector pulse. I tried starting the car with starter fluid and it turned and and ran without shutting off. The injectors also started pulsing after it was on. But when trying to crank it will not pulse injectors by itself. Any ideas ?
weendoggy
This sounds like you don't have the ignition feed HOT in Start mode, just Ignition mode. It needs to see both at the Start (cranking) mode. By what I read, you start it with fluid and then the key in Ignition cycle (not start) and it runs fine? If so, that's the place to start. Also, using stock ECU or Control Pack? What Gen?
DDautodetailing
Power by the hour control pack. Gen 2. I put fluid in . Then crank the car and it starts
Dlm75
