2007 Crown Vic, P71, approx. 124K 4.6 2V. In May went to visit my son in Orlando and on I-4, in the middle lane of like an 8 lane interstate, the car quit. now that was an adventure at 65mph. lights on the dash on, no CEL, no codes when I scanned it.
Started up again after I got to the side of the road. got to his place, checked battery cables, negative was very slightly loose, hard to turn it but you could. tightened it up, drove all the way to the right the entire rest of my trip. nothing happened.
fast forward to august, has happened twice. once it first would do nothing, then it would crank and not start. other time, no crank. like no battery, except lights on dash on and radio, just like Orlando incident.
replaced the crankshaft position sensor, just in case. then the third time, after that it did it. no crank, all lights, etc. on.
tested the battery, battery showed low charge and dropped to 10v when cranking. Optima Red Top, second one as the first one only lasted two years. this one is 2.5 years old. rest of charging system all good. so I replaced the battery. waiting for the next time it almost gets me killed...always in busy traffic. car is not overheating, no loose grounds I could find, no frayed wires so far, never a CEL and never a code after the failure when I scan it. only way to see if anything I am doing is to drive the car and see what happens. getting old driving in the right lane all time!!! A/F ratio is always good. no prior warning...just stops. doesn't matter if stopped or while in motion. no consistency to it that I have been able to determine. not even time, as it was months before it did it again. then had done it about 3 times in the last month. another reason I am and did lean towards the battery. When the first one died, lights and all worked, just would not crank. no click no nothing which is what it is doing now when it does it. usually only lasts a few minutes then the car starts right up and doesn't do it again for a period of time.
Any ideas? I drove it to my daughter's Monday and back which was about 40 minutes both ways, no incident.
