Cylinder head
Acmerica
Ohio
Needing to remove cylinder heads on my 4.6 2v what all needs to be removed to take out head bolts?
96blak54
Staff member
Lawrenceburg Kentucky
If you are asking whats needed to be removed to remove the heads.....Remove valve covers, harmonic dampener, water pump pulley, steering pump, front timing cover, timing chains. It can be a task but not a difficult one.
Acmerica
Acmerica
Ohio
That is what I needed to know. Thank you
would this help?
yea its a truck so there will be some things that are different but it gets you in the ballpark of what to expect.
Snorky
I'd recommend pulling the followers as well before you remove the timing chains
I_LIKE_TURTLEZ
USA
It's a job. Pay for a week of service data access from Ford and follow the instructions, last thing you want is the mechanical timing getting screwed up, luckily it's a 2v.
We should have never moved away from pushrods in v-engines, you can take apart an LS in an hour. One chain.. one man.. sigh.
Dlm75
