D3v's drag car build
D3VST8R96GT
Marble Fall, AZ
This is 1 of 2 builds I have going on. I was gonna start last summer but my kiddo needed surgery so it was postponed and then I had bad machine shop too.....
Cleaning the teksid
Main bearings
Crank is in
I need to drill a hole
Boom hole made
http://images.tapatalk-cdn.com/15/04/25/9b030984b4b5390a273c2b90b41a2322.jpg[/IMG
Gaskets and head studs in
[IMG]http://images.tapatalk-cdn.com/15/04/25/adc2d14372000341f3f3ac5dcacdaf97.jpg
Found out I needed to tear down the heads more so I had to stop there until may
Very cool build! What kind of heads are running on this thing, and what compression are you going for?
D3VST8R96GT
D3VST8R96GT
Marble Fall, AZ
Team lower control arms installed today
Rear springs have 1 and 1/4 coil cut.
Fox 4cly need to be installed but I can't get the shocks off Lol probably need a new impact.
Also waiting to get strange 10 ways for the front and rear.
D3VST8R96GT
D3VST8R96GT
Marble Fall, AZ
Worked on the motor again.
Heads up for anyone interested in putting 3v head on their car. Get the heads drug for a 2v/4v and set them up like this.
After you have lubed up the threads, put the head on and drop in the studs. Mine is an allen key and used that to put them into the block. Then started tighten them all down by the nut.
Also got my oil pan in
D3VST8R96GT
D3VST8R96GT
Marble Fall, AZ
Still working on this thing.
Truck is getting head studs, after that I can tear down this car a little bit. Going to be doing 4.10 gears and messing with the trans (super J-mod, cooler, and massive stall)
Also got another engine for the '96 that needs to go in.
D3VST8R96GT
D3VST8R96GT
Marble Fall, AZ
Its been a really rough year....
Hopefully 2017 is more kind to me
Sent from my VS995 using Tapatalk
D3VST8R96GT
D3VST8R96GT
Marble Fall, AZ
I haven't done much with this project sadly I might sell the car aside from a fuel system and tune the motor is mostly ready to go in ..... My white car has had A LOT of progress because I have a huge sentimental value towards it. The silver car is eh.
virocanah
