debating over heads ?
96TANGERINEGT
Ok so I am kinda shoping for heads a bit . I came across frpp heads for 4.6L 2V .
Problem is they all come with cams and I am not gonna want stock PI cams for what may be going together , so anyone know of a place to get heads with out cams that aren't 2K a set . Yea I have looked at some stage 3 heads for like 1800 witch is not a bad price , but I am gonna try and put this together a little cheaper then buying a 2000dollar set .
I mean I guess I could just buy them and take the cams out and sell them witch is what I may end up doing ...
Any other suggestions. I can't belive my phone is actually working on here right now . Its real slow though. Lmao
96TANGERINEGT
96TANGERINEGT
What ? Thats kinda dum
Dosnt say anything about that where I found them
96TANGERINEGT
96TANGERINEGT
Just save up and fork out the money for TFS heads
Hahaha. I did look at them but dammmm that's a lot of$$$
Plus the ones I was looking at have smaller chambers , for a bit more comp. Witch is the end goal here
Musturd
Well figure it out homie , I would go tfs if I was building a 2v or just a simple a pi swap with cams ... I've got my ideas of what's fun ... With a pi swap with some nasty cams long tubes and supporting mods I'd be happy and then is throw boost at it because I'm not scared of 10.5-1 compression unlike every pansy on this forum .... Shit my car makes around 10.3-1 and I'm pushing 15lbs like a boss
96TANGERINEGT
96TANGERINEGT
How far do u think PI heads would have to be choped to get 10.5-1. And with a set of 278 cams I wonder if the pistons qill have to be cut . I am gonna be going with that victor jr intake so flow on the top end should not be a problem , the heads are gonna need a little attention tho or that intake will be pointless. Lol
I have always liked that intake .
Musturd
Bolting on pi heads on a npi shit box will get you around 10-1ish maybe a bit more ... That alone is a great gain with the combo your talking should make 330ish with pi heads , you will have to fly cut the pistons I'm almost positive
96TANGERINEGT
96TANGERINEGT
I was hopeing not to have to go into the bottom end , I wanted to get some things together put on . Then when it blows up go to the bottom side . Lol
I could probably dremel the reliefs out while still in the block , but dam gotta be carefull
Br1anh
