Want To Buy DELETE! ‘94-‘95 Cobra or GT Smog pump & vacuum lines
Daryl
Somis, CA
Preemptively looking for a smog pump &/or the accompanying vacuum lines with valves, solenoids, etc… I’d appreciate a reply or PM! So, if you did the smog delete and still have working components and are willing to part with them, let me know!
Thanks!!
07GtS197
Fort Myers, Fl
Have you tested yours first? I don’t think the smog pump is to blame but one of the diverter valves could be to blame or even a vacuum leak from one of the million vacuum lines associated with it.
Daryl
Daryl
Somis, CA
I’m definitely going to have my mechanic go through it. This thread is “preemptive” just in case I end up needing one.
07GtS197
Fort Myers, Fl
If it’s not making noise it’s probably working. Most of the time they’ll lock up when they fail. Also I’d be weary of someone looking at it unless this guy has been a mechanic since these cars were new. Most people ripped out their smog system instead of having it fixed.
RAU03MACH
NEW MEXICO
how to test a 95 gt mustang smog pump
To test the smog pump (Thermactor air pump) on a 1995 Ford Mustang GT, check for physical airflow, inspect the belt-driven mechanics, and test the surrounding vacuum and control valves. [1, 2, 3]
1. Check for Physical Air Output
  • Start the engine: Let the 5.0L V8 idle and reach operating temperature or start from cold.
  • Disconnect the output hose: Pull the main air outlet hose off the back of the smog pump.
  • Feel for air: Place your hand near the pump's outlet port; you should feel a steady, strong stream of air pushing out. [1]
2. Inspect for Seizure or Belt Noise
  • Check the pulley and belt: The 1995 GT smog pump is belt-driven continuously by the serpentine belt (it does not have an electronic clutch). [1]
  • Listen for noise: Chirping, squealing, grinding, or a heavy rattling sound from the pump unit usually points to internal bearing failure or a failing rotor. [1, 2]
  • Check for a seized pump: Turn off the engine and try to spin the smog pump pulley by hand. If it refuses to turn, the pump is seized and must be replaced or bypassed using a shorter serpentine belt
Daryl
Daryl
Somis, CA
Skip it…at least for now. Tested mine and it’s still working.
Beefcake-Racing
