Do I have a pinion seal leak?
martinbaca18
I noticed there a leak above where the drive shaft and the differential connect. But I do not see any oil on the pinion seal or around the u joint. It's just above it. Looks like something is spraying oil up towards the rear seats. I don't know what it is. Any ideas? -2001 Mustang GT
martinbaca18
martinbaca18
It has lowering springs so maybe the pinion angle is causing this leak?
Does it actually drip on the ground?
Take a pic if you can.
martinbaca18
martinbaca18
No it doesn't drip to the ground. I'll take a picture when I'm off of work.
martinbaca18
martinbaca18
Hard to tell. It almost looks like there was a leak. And it was fixed, maybe someone sprayed some pb blaster at the flange bolts to remove them. They look like they were off relatively recently.
martinbaca18
martinbaca18
Yeah but I just got new mufflers and it just burn the fresh oil
Did you have any other fluid leaking and maybe getting slung around the driveshaft or pinion? In the 1st set of pics the seal looks dry at that angle.
Kboss87
Southeastern, PA
A little bit out oil will make a huge mess due to the pinion spinning. Check the fluid level, top it off, and check it again next time you have it up in the air.
marktuck99
