I have my HIDs there now on the drivers side, might follow your lead on the pass side. But yes pics please.
Heres a few pics that I took for someone on another forum. Theyre not the best because the car is on the ground, but you can see the idea:
Coming out of the drivers side valve cover...
Coming out of the passenger side valve covers...
I have the two hoses routed to the passenger side frame rail under the cold air intake tube. I installed a Y fitting that runs the two separate hoses into one, and I have the single hose ran under the frame rail, behind the fender liner, and over to the catch can....
Thanks man! I had a hose coming off of my cold air intake tube that ran to the drivers side valve cover, and a hose that ran from the passenger side valve cover to the intake plenum. I capped the fitting in my cold air intake tube, and installed an NPT plug in the intake plenum.
not sure if you guys have read this before..
http://www.sn95forums.com/showthrea...rtation-and-the-Alternatives-(Updated-4-02-07)
This is a non ending discussion. . Trial and error. . I like the simplicity of open breather. But it's a known fact that it will work better with some vacuum at the crank case. .
Enviado usando mi SHP-L710 usando TapaTalk
Yes they are. Fortunately the 5.0 is not that way. I still haven't got around to the 4.6.. on the 5.0 I got a fitting welded on. When I get started on the 98 I'll have to figure something out..
