does clutch size have to be exact? 2001 mustang gt 4.6 2v
MiStangGtBangs01
st. louis mo
when replacing a clutch does it have to be the same size i have a 2001 mustang gt i bought i dont know the clutch size ive seen them between 10 and 13 inches for my car i do all my work at home myself im short on cash so i cant drop my bell housing to check then reseal it right now any help would be very appriciated
thanks for looking :headbang:
MiStangGtBangs01
MiStangGtBangs01
st. louis mo
i have a t-45 my tags a tr 6 so im guessing ony a 10.5 will fit? and any brand really Im going to get a stage 2 i don't really like my stage 3
Musturd
Yea some have a 11" clutch and most have a 10.5"
rz5.0
Great state of TEXAS
I tought 99+ went 11"
Or when ever they swap to the 3650.. I tought the 6 bolt and 8 bolt was different between the cobra crank and the gt crank. .
They can have either size clutch and also either a 6 or 8 bolt crank. That said, it can screw with ordering flywheels when youre not 100% of what yours is
lutter94
South Dakota
But then you have to have a different bellhousing if you have a different flywheel, starter won't line up. Just stick with what was on there.....any brand will work, I like my exedy. Haven't exactly tried any others, just swapped to the 5 speed recently.
dino
Match the clutch to the flywheel and you're good to go
MiStangGtBangs01
MiStangGtBangs01
st. louis mo
so now to figure out how many bolts i have ill have to actually look wont I?
from what im gathering the t45 its self is a 6 bolt and some are 8 bolt correct?
and the spline is that always 10 for the t45
dino
Spline will be 10.
6 or 8 bolt depends on Romeo or Windsor motor. Can count the valve cover bolts to figure out which you have. Being an 01 and assuming it is original, it *SHOULD* be a 6 bolt Romeo. But I've seen some anomalies, and never know if it had been swapped...
Musturd
The flywheel diameter is the same size
dino
That's true. Bolt pattern is different. Flywheel diameter is same.
Musturd
Yea I put a 11" clutch in my old 2v that was 10.5" car
TreeScholar
