Rice_slayer
- Joined
- Sep 28, 2007
- Messages
- 4,352
- Reaction score
- 58
Well, since my car is apparently making some power now, my suspension has become a limiting factor. Here is the video of my car launching and running, 60 was 1.69 in this pass.
[video=youtube;QbawvZYiXyA]http://www.youtube.com/watch?v=QbawvZYiXyA[/video]
Current set-up on this pass was as follows: Stock mach 1 springs, cut 1 coil in the front, uncut rears, MM rear LCAs, tokico 5 way adustable shocks/struts, fronts set to 1 (softest) rears were at 3(medium), no front sway bar, and 26x8.5x15 et drags at 12psi. I was only launching at 4500rpm, but the car squats and "bounces" a lot as you can see when I shift. Just wondering what are some good mods to look into to help get the power planted a little better. I am changing my wheel setup to SVE drag wheels, 17 fronts and 15 rears with 28x10.5 et drags. Also looking into full length subframe connectors. Anything else I should do? I think the car's suspension is absorbing a lot of the launch momentum :/.
