My drivers seat wobbles back and fourth if no one is sitting in it. Is this a common problem? I checked and all the bolts are tight something in the track must be loose. My guess is that its from getting pushed back in the seat so many times that something either broke or got bent. Dan
you might want to check all of the brackets where the seat rails bolt down because i had the same problem and it ended up being just a bracket that i rewelded
We have weak aluminum tracks that brake easily! Very common problem, they switched to steel on the 99+ it was so common.
On mine the part that bolts to the floor actually broke off the tracks. I have heard that its pretty common. I just took it off and welded them back.
Ok thanks for the input guys. One more question. Can I put 99+ leather seats in my car front and rear without any modifications? My seats are in pretty good shape for a 95 car but I will eventually want MINT seats for the car, also will the gray match 100% or did they change?
