Ebay turbo what u guys think
romagna127
I know it's ebay most of u will say not to get it or you get what u pay for . Has anyone used this kit if so what can u tell me about it . If anyone wants to read about it and let me know what u think thanks Check out this item I found on eBay: http://pages.ebay.com/motors/link/?nav=item.view&id=131132747365
Sent from my SCH-I545 using Tapatalk
the5.ohh
Shaolin, NY
[MENTION=18400]1bad9d5[/MENTION] is runnin an On-3 turbo on his 5.0 - Do yourself a favor and buy it off Latemodelrestoration.com or straight from ON-3
Just because 1 person is running it doesn't make it a good kit lulz.
It's a decent kit with a great price and a bit of custom fab required to make it work. Then again, basically every cheap turbo kit will require lots of work.
Musturd
The 94/95 kit is supposed to be the best fitting out of the box kit they have released ... Of course there will be some minor tweaks here and their . For the money you can't beat it and the link he posted from ebay is from on3performance . Even one of the long time members is using there kit on his sexy new build addrmk2 . I was originally going this route but went cog driven blower instead
romagna127
romagna127
Ok as for my top end what would u guys do would u go with heads and cam or would I be ok with stock
1bad9d5
Westchester, NY
the On3 kit I found for my car was initially off ebay and then I called them and bought it.. that 1500 isn't the whole thing but I got most of my stuff from them except the injectors are ass and I got my BOV somewhere else as well because my kit didn't come with 1.... 95% of the kit installed with no issue, some piping issue I had, but I converted my TB setup to a fox which made everything fit easier.. I love the kit, only blemish is I have an exhaust leak from the moment I installed it, still haven't addressed it lol.. overall the kit is great and produces plenty of power.. mid 400s for me
romagna127
romagna127
You running the kit with all stock parts or do u have heads and cam
Addermk2
Call and talk to Chris from PowerAdderSolutions. You'll want the Y pipe, and the PAS maf + harness.
Sent from my CyanMobileX Evo 4G
1bad9d5
Westchester, NY
yea, stock t5... but its a ticking time bomb... I wont be running the car too hard at all daily or weekly but when I come out of the hole 4-5k deep at the track, im sure the tranny is eventually gonna leave itself there lol.. I also have 0 clue on which is the best option to replace it with.. so im just waiting for it to blow lol
Win
Kennesaw, Ga
Just roll ill into it at the track, plus double clutch at the track and your set so you don't grenade it.
Replace it with a 3550
your short shifter clutch cable and clutch bellhousing will all work. And handle double the power of the stock T5
Addermk2
Um... no. 3550 is a marginal transmission. The shifter is not the same. The SN bellhousing will not fit it, neither will the clutch fork.
If you are going to upgrade your trans, get a tko600 with an aftermarket bell. Then add an mgw shifter. The new trans will require a new clutch.
gjhanick
