Mike Honcho
- Joined
- Oct 2, 2019
- Messages
- 38
- Reaction score
- 3
My egr valve was taking a dump on my car so I decided to delete it. Pulled the eec, took it to a tuner and had a chip burned to disable egr and thermactor functions(smog pump had been bypassed by previous owner). Got the eec back in the car, test drove it, no more egr codes. LMR screwed up and sent me the wrong egr plate, so I deleted the smog system and all vacuum lines for smog/egr while leaving the egr on the manifold. Drove the car off and on for about a week, no issue. After that week the car started throwing a CEL for egr codes, specifically 332. Then while driving it felt like the car would randomly cut fuel for a split second and flash the CEL(I would assume the eec is trying to run the egr so it's cutting fuel and advancing timing, but not sure). Again, code 332. Egr plate shows up, delete egr the rest of the way, car throws code 327. Contact tuner, he has me bring the car in, they check the chip(moates), and verify egr and thermactor function are disabled. They tell me there's nothing else they can do and recomend a $1k stand alone. The car shouldn't be throwing egr codes with everything disabled. The car never had the drivability issue before the chip. If the chip is tuned correctly, I'm starting to think the eec isn't reading it. Leads me to think possible corrosion on the terminals or a lack of contact. Has anybody ever seen anything like this before? I'm planning to pull codes one last time tomorrow(cel is on almost constantly now), pull the eec, remove the chip and start checking the contact points. I don't really know what else to do at this point, I don't know how the car didn't throw any egr codes for a week. I'm really starting to consider a stand alone just to be done with it, just hard to justify spending the money on a car that isn't built and I'm only $2400 into.
