Hey guys. Since the motor was built, it's been consuming oil like crazy, an abnormal amount, maybe a full quart every 300 miles or so. Granted most of those miles are on the track, but that still seems a bit excessive to me. I can see it smoke through the tail pipe, it's pretty visible. I've had the motor checked out, and compression is still pretty decent (between 180-190 psi across all cylinders), leakdown is between 9-11%, and the motor still makes pretty solid power. Is it possible for all this to to be within spec, and still have a major oil consumption?
