engine stall when removing oil cap
kevsmustang
Im in California with all the smog stuff to deal with so the car runs good but when I remove the oil cap
the engine like sucks in air through the opening then chokes out and dies some times it will almost stall then bounce back and idle but most of the time it just dies any one experience this and how can I fix it 1998 v6
K
kevsmustang
The engine is stalling because it's letting a huge amount of unmetered air into the engine.
trying to find out why? pvc is good sprayed around intake any other ideas why its pulling so much air into engine
lwarrior1016
Mr. Secondary Timing Chain
South Mississippi
Time out guys. The pcv goes to the intake and the intake sucks pressure (air) out of the crankcase. If you open the oil cap while running you are introducing a bunch of fresh air in to the crankcase in turn going in to the intake, that’s the definition of a vacuum leak. Take the hoses off the intake pipe, the ones going to the pcv and manifold, then plug off the intake pipe holes. Now run it and see if it dies with the oil cap off. I’ll bet it doesn’t.
