Exhaust clip w/ LT's and o/r x pipe
B
blackfang
Car has a noticeable gain in power from low and midrange. Right now i am running lean so I am gonna richen up my tune until JMS can send me a new tune file.
The install wasn't too bad. The x pipe part was a b!tch as it was off a bit.
B
blackfang
Tabres said:
You have Flowtech long tubes, yes?
Do you have any leaking issues with them?
Just a tad on the slip fit which is normal with them. Now I have them installed and have clearance, I am going to weld the slip fits.
94gtstang50
They sound nice, have a mean tone to them, probably sounds awesome when you get on it.
STNG_96
sounds real good, wish I could get some lt's, how was the install?
B
blackfang
It wasnt that bad, just undo the steering shaft to the pinion, wheels, brakes, shocks, swaybar, 8 bolts on the k member and supported it on jackstands. Then raised the car about 1-2 feet higher and let the motor lower a tad and it gave perfect clearance.
The bolts on the headers can be a pain at times. The hardest part was lining up the flowtech x pipe which was completely fvcking off. Makes me wonder if they even installed one one a car before marketing it. Just had Monty@JMS retune my files and I loaded them in. All thats left is to weld the slip fit which should take 2 minutes.
marktuck99
