Explorer diff in a SN95/1994 GT?
Monsterbishi
Christchurch, New Zealand
ok, as some know, I live on the other side of the planet in New Zealand, so have limited local parts access for rwd Ford cars, so I'm wondering whether there are any Ford Explorer diff's that I can bolt straight up to my car without changing any axles, etc?
Means I can then drop out my factory one and build it up without missing any track events.
95Grandtouring5.0
Explorer had a better flowing intake and the explorer also had gt40p heads. The gt40p heads are said to be better then the gt40 heads, because of how the head was designed a little bit different, but it has also been rumored that if your going all out then gt40 heads are better. Also if you want to put the gt40p heads on your 94 gt, you will need different exhaust manifolds seeing has how these heads are slanted different.
MeanGrn Gt
I believe he is wondering about the differential not the motor. I dont know but maybe someone will chime in here.
95Grandtouring5.0
oh, I have no idea then.
ryclef331
It should work just fine. I'm not 100percent sure that it isn't a 31 spline diff. I know F150 8.8s are 31 spline. I think you'll be fine though.
S351R13
The explorer is 31 spline. You would have to change the axles.
bahndrvr
Yeap it will work but as stated the axle shafts are longer on the exploder's.
