Failed emissions
jcfzn2000
MO
I just bought a 2003 Mustang GT with the 4.6 L. I replaced the battery shortly after the purchase, and now I cannot get the catalytic sensor or EVAP sensor to read. I have driven the car several hundred miles and even took it to a mechanic shop and they replaced the EVAP canister because they said it was leaking. I have not had any check engine lights come on, but I did have a check fuel cap come on. I replaced the fuel cap and have not driven it much since, but the mechanic shop said that it may be the purge valve. It seemed like they were just throwing parts into it and I was tired of spending money. Has anybody else had issues with not getting these two sensors to read?
07GtS197
Fort Myers, Fl
What codes is it throwing? Usually you have to do x amount of miles at varying speeds and x amount of drive cycles after the ecu has been reset.
J
jcfzn2000
MO
I was going to do some driving this weekend but there are no codes
weendoggy
This should be caught with a good scanner. It will read codes if there are any, even if minimum. Also, most states only need the OBDII port to gather information for emission testing. The ECU keeps the data, but as mentioned, you need to put varied drive cycles on the car. Usually a day or so.
07GtS197
Fort Myers, Fl
What specific sensors are not reading? If the car is running and driving just fine they’re not important sensors. Keep driving and don’t worry about it if that’s the case.
Lucky57
