Famous door panel ripple?
Ineedav8
South Florida
I can't be the only one that has the vinyl creases and lifts off the door panel is the a solution to fix this besides buying new door panels? I'm tempted just to cut out the Insert and make a little patch kind of deal like the 240 guys with bride logos blended in the inserts and seats
white95
Apex Junky
Prairieville, LA
Do it and take pictures!
That South Florida sun will do some damage to an interior.
Is it peeling at the top or the pad area behind the controls?
1997GT4.6
Mine is doing the same since the previous owners kid cut a gash in it. Now its wrinkly and the gash is about 5" inches long.
Tony
ohio
funny 5 yrs in phoenix didn't do anything to mine then.
ok? some fuuk up and some don't then lol.
anywho my old gt started lifting behind the plastic cup area. i took the cup off.....went ahead and peeled a little more back to get a decent opening to shoot some 3m spray adhesive in there....let it sit for about 10 mins...pressed it back down and ran a heat gun over it a few times while pressing. ya never knew it was there....hope this helps
Ineedav8
Ineedav8
South Florida
It's around the "built in armrest" area I tried some adhesive spray but didn't use a heat gun I'm going to try that in a little bit when I get out of school
Ineedav8
Ineedav8
South Florida
Sorta like this but I don't know about the pattern layout the overall theme of the idea I like just thinkin with matching seats to blend the interior a little
Tony
ohio
yea as long as it's not cracked...can't tell from the pic. you should be able to glue that back down. start from the back and sorta smash it down as you go forward to make sure there's no air bubbles. the heat gun helps a lot.
but i don't hate this idea lol. love bride seats too but $$$$$
Ineedav8
Ineedav8
South Florida
Sweet thanks for the heads up! And there not cracked just used and abused it's pouring now hopefully later :( I know there so pricey but I may go with a set of trs' s down the road
SnakeMedic
Roseville, CA
Oh dang! I have this too... stupid convertible being exposed to heat. Now I know how to fix it! Man, this site answers questions I have before I ask them!!
Thanks!
if it is cracked, 94-96ish has that insert that goes over that area. You would have to drill some holes in the panel but you could find one and put it over it.
Ineedav8
Ineedav8
South Florida
I did the el cheapo screw for now till I get replacement pieces but heat gun and some glue like Tony said
Twista
Never seen that in my years of owning a sn95 stang.
Tony
ohio
shit i'm in ohio and both of my door panels were like that. 1 when i bought it and the other followed soon after lol. i see interior pics all the time with the bubbles in that same area lol. pretty common
Luckily mine hasn't done that.
If it does I will recover in black perforated vinyl to match my FR500 steering wheel and RSD similar to the 94-95.
LaserRed95GT
So I'm swapping my interior to dark charcoal right now and have the 95 door inserts, you're saying that if I cut out the vinyl (sun damaged like above) it'll fit into the door no problem, with some adhesive?
marktuck99
