the5.ohh
Ive vey never seen that in all my eBay searching.
Just realized there not X heads. But pretty nice heads for 600 or less
You should save 8-900 dollars in a savings account and just find some trickflow twisted wedge heads on the internet. Wish I did, trickflow just make the best out of the box heads for a 302 and if your gonna do it, you should do it right the first time. Gt-40 heads are cool but again anything is better than stock lol. Then you get that explorer intake, stage 1 cam and all the rest you should be at 2000 bucks in the end. The porting and polishing is still not close to a trickflow ootb IMO.
where do you get that 400 dollars from? your area probably differs in labor for port work and assembly, but 400 isn't getting a set of ported and polished, rebuilt heads. I know because my friend put some on a fox of his and it came out to $700-750. For $150 dollars more i'd go aluminum and better flowing heads and not wait on a machine shop to take months. Plus its 2.02 valve, come on man.Tfs 1 can't hold a candle to a wolverine grind. It's been proven.
Hmm 400 vs 900 for the same power #'s
i choose 400
There's nothing wrong other cams but he said he wanted to run a stage 1 trick flow cam which is just fine if he's running a explorer intake to help with bottom end torque because of the heavy body and transmission. I've heard good things about the wolverine 1087 cam tho.
I can pull gt40 heads for 200 every day 125-150 gt40p. Machine work porting polishing and assembling 200-250.
So yeah 400 bucks
plus Joe has a friend that will be doing the work for him. So yeah 400 vs 900. Kind of a no brainer if you ask me.
Is 500 dollars worth maybe 10 hp more. Nope
The Wolverine 1087 cam grind is being duplicated. And works amazing with the gt40/gt40p with the 1.7 crane gold. People pull 280-330 depending if they do port work on the intake runners. It's a tried and true proven combo.
Sometimes it's like talking to air. Some people don't read.
Your saying these heads are cheaper and will make the same amount of power as aluminum heads with port work and a 1.84 intake valve, yeah I guess you are the man to talk to about combos when your trying to put a 5.3 in your shit.
See you still couldn't even read.
Quoted myself so you can read and not sound so asinine.
Also so to pull yours in here. Where in this sentence or rambling did you say anything about porting the alum heads.
oh don't forget I did own a 347 that would wax 99% of the cars on this board and most on the street. Oh also I duplicated that exact combo he had except I did the wolverine cam.
Give up man. I just caught you in it all.
We were talking about prices after putting all that work into some stock ford heads. I was saying it will not be worth it and better off getting other heads.
and that's how good your reading skills are, I said that, "same amount of power as aluminum heads, with port work and a 1.84 intake valve" Gt40 heads have the 1.84 valve and are obviously the ones getting port work.
So the mechanic is going to put everything together, great! a job like this I use to charge less than 500 bucks to do. If joe had another type of transportation he can do it himself, one of the easiest motors to take apart and put back together.
That's cus 99% of the cars here are v6
Enviado usando mi SHP-L710 usando TapaTalk
Ha.. a lil exaggerated. . 50% v6 49% npi
Your not worth listening to. You obviously don't understand what you say first off. You never said that till after the fact. Get your Sh*t straight man.
Bc obviously if you would have said that before I said that at 1837. I wouldn't have said what I did.
You didn't even say that till 1854. Nowhere in any of your comments before hand did you say that. Did you? Nope you didn't.
