Terrorist 5.0
- Joined
- Oct 16, 2023
- Messages
- 584
- Reaction score
- 236
Hello everyone, I'm looking for a more precise adjustment over the preload on the throwout bearing.
A little background, I like my clutch to grab low. I don't want to say excessively low, but low. Anyway, did a 1st gear pull, went to shift, the clutch pedal went to the floor way easier than normal, and I couldn't pull out of 1st gear. Tried adjusting the quadrant for more preload, and the problem went away. Not sure why it just started out of nowhere.
Best I could come up with was that was my generic cables last straw, and now stretches when the pedal is pushed, OR, one setting on the quadrant stripped. I can't see it. Anyway, if anyone has explanations, please feel free to spitball. I'm curious. Anyway, went home to replace the clutch cable (need to reroute it), and now the problem is much better. However, my pedal grabs differently now. I would like to have it like before, but with the limited settings of the stock quadrant, I can't set it to where I feel it is normal.
For this reason, I want to make the move to a Maximum Motorsport quadrant (stock quadrant radius), and some sort of firewall adjuster. I plan to use a stock style cable. My questions are, any suggestions for a firewall adjuster? And how much better adjustability (think how precise) compared to the stock quadrant?
As for my shifting problem, I'm not 100% on it being a cable issue. I am going to look underneath the car and see if I see anything out of the ordinary during clutch action. Thank you.
