First time mustang owner. Need help
JohnnyLS89
Well I recently purchased a 1995 Mustang GT S 5.0. Well the car has a few issues. For one the car doesn't want to rev over 3k when driving or in nueteral and is very sluggish. No CEL or any codes are thrown and I have no clue what to do since this is my first mustang. Any help would be great. It has 140,xxx miles and Automatic transmission
It sounds like what my 1st 5.0 did after it jumped time. Mine had original timing gears/chain and it jumped a tooth. Lost almost all power above 3K.
Could be ignition as well, does it go to 3K and stays there like a rev limiter? Or just looses power and climbs slowly?
JohnnyLS89
JohnnyLS89
Idk I haven't tried over that because it revs up so slow
Sent from my LG-LS980 using Tapatalk
As step one, I would make sure you have the correct firing order and timing set to 10* BTDC.
If you're not sure how to check or time it, just ask.
JohnnyLS89
JohnnyLS89
I have no idea how to time it
5.0
Nc
Clean your maf as well, might help some.
JohnnyLS89
JohnnyLS89
I'm about to start looking at it now
OK, make sure the firing order is correct in the above pic. Ford has 2, HO and non-HO. People mix them up.
For the timing, do you have a light?
You will need a timing light. Mark the crank at 10* BTDC on the scale, scale is on the harmonic. Use whiteout, or a black sharpie.
Clamp the light sensor to the #1 plug wire, remove the spout (small connector under airbox), start car and point timing light at crank pointer just below alternator. Your mark should be light up by the timing light strobe. If not, you'll ave to loosen the distributor clamp bolt (just loose), then you can move distributor while watching the timing light marker.
[video=youtube;iqVzHmpSdsk]http://www.youtube.com/watch?v=iqVzHmpSdsk[/video]
^General idea.
JohnnyLS89
JohnnyLS89
Gonna check the fuel pump. Timing is in order, firing order is correct, MAF is ok. I think it has a vacuum leak
JohnnyLS89
JohnnyLS89
Drained the tank and put new 93 in it and revs up to 6k now. Shift linkage broke while I was at the light though so only have reverse now lol
Oh. You didn't say it had fuel from the 90s. Lol
JohnnyLS89
JohnnyLS89
I had no idea either. Just tried it and it worked
Burninrock24
Minneapolis, MN
If all that's happening at once I'd say the car just sat for a really long time. Time for a spring tune up! Especially while it's new to you, before you get too lazy.
JohnnyLS89
JohnnyLS89
Issue came back after starting it today and now has a misfire
Burninrock24
Minneapolis, MN
Sounds dumb, but seafoam it. I've had the dumbest stuff fixed by seafoam. Just don't put it in your oil. Just half through a vacuum line and half in the tank. Otherwise, I'd start pulling plugs replacing wires if needed and looking for vacuum leaks.
JohnnyLS89
JohnnyLS89
I'll have to try it.
JohnnyLS89
JohnnyLS89
I was told to check wires, plugs and distributor. Also fuel filter
toyman
^^ yes, that as well. I would do a complete tune-up to establish a baseline. Check the obvious first, such as the plug wires shorting against the headers, the wires are fully seated onto the plugs and the battery to engine and engine to chassis grounds are clean and tight. Don't forget the air filter.
JohnnyLS89
JohnnyLS89
I took the air filter out because it was dirt as hell lol and my SR intake came in from American Muscle
JohnnyLS89
JohnnyLS89
When I rev it up it revs alot faster then with the old gas in it but it feels like its hitting rev limiter at 3.5K rpms
