Flat lining at W.O.T!?!!!
Discussion in '96-04 - 2V Specific' started by Ineedav8, Dec 13, 2015.
  1. Ineedav8
    Ineedav8 Active Member
    647
    Mar 1, 2013
    South Florida
    Think something along the lines is wrong at a certain rpm band per say 3,500 in 3rd the car will flat line like it hits a brick wall rpms wont budge i know i have a cracked msd coil pack (My. Spark. Died.) Fuel pressure is good 40lbs last i checked off the fuel rail. Gunna do some maintenance and buy some tr6 plugs and do a compression test to see where im at. Just wondering if anyone else has had this problem car runs and drives fine other then that. So I avoid merging into traffic as much as possible
  2. Ineedav8
    647
    Mar 1, 2013
    South Florida
    At W.O.T a/f is at a high 13/ low 14
  3. 07GtS197
    07GtS197 Well-Known Member
    1,433
    214
    Mar 16, 2015
    Naples, Fl
    Is it throwing any codes? Did this arise after you did something or something happened? How old is your fuel pump?
  4. Ineedav8
    647
    Mar 1, 2013
    South Florida
    No codes. Pump and filter were installed maybe a 4/5 months ago and haven't done a thing since its happened only interior work
  5. 07GtS197
    1,433
    214
    Mar 16, 2015
    Naples, Fl
    Did this start all of a sudden or gradually?
  6. Ineedav8
    647
    Mar 1, 2013
    South Florida
    All of a sudden
  7. Ineedav8
    647
    Mar 1, 2013
    South Florida
    Thinking spark wise
  8. 07GtS197
    1,433
    214
    Mar 16, 2015
    Naples, Fl
    Im not so sure because with your afr being on the lean side it wouldnt be caused by spark. If it were a coil going out youd run rich from unburnt fuel. Plus you dont have any codes so I highly doubt its spark or fuel related. Have you checked your tps? Also is it a stick or auto?
  9. g36 monkey
    g36 monkey Moderator Staff SN95 Supporter
    14,057
    543
    Nov 15, 2008
    Orlando, Fl
    Clean your MAF, try to pull codes, sometimes the light doesn't come on and codes are there. 02 sensors have caused such a scenario before for me.
  10. Ineedav8
    647
    Mar 1, 2013
    South Florida
    Bought some bad 93 I think filled up to 3/4 today and the flat line is gone ? Bad gas can do that say whaaa lol and its a stick. Tr3650. I'm not sure it's just a bad tank but i will see
  11. 96blak54
    96blak54 Legend
    7,666
    1,001
    Feb 21, 2011
    Ky
    Makes sense. Could have gotten mostly ethanol with that mix. That would have put injectors around 35% higher duty cycle....so yea. You were leaning out just because injectors couldnt keep up with demand. This could be one scenario.
    Glad its running good!
  12. g36 monkey
    14,057
    543
    Nov 15, 2008
    Orlando, Fl
    WOOT! Crappy gas for the lose!
  13. 07GtS197
    1,433
    214
    Mar 16, 2015
    Naples, Fl
    Damn racetrack gas got another one...
  14. g36 monkey
    14,057
    543
    Nov 15, 2008
    Orlando, Fl
    Racetrac has been stepping their game up though, at least around here. I generally prefer their stations now over most others
  15. 07GtS197
    1,433
    214
    Mar 16, 2015
    Naples, Fl
    I like their frozen yogurt but their gas, ehhh. I havent been driving recently so maybe they have been getting better but I dont know lol.
  16. evilcw311
    evilcw311 Most Evil Member! SN95 Supporter
    7,459
    2,080
    May 9, 2010
    Louisville, KY
    You have to be a chick. No straight guy in his right mind would admit to eating frozen yogurt!!!!!!
    We eat ice cream with extra sprinkles!!!! :)
  17. 07GtS197
    1,433
    214
    Mar 16, 2015
    Naples, Fl
    [​IMG]
    Damn my meme wont work :(
    and oh em gee sprinkles are like da bomb on chocolate chip cookie dough ice cream!
  18. g36 monkey
    14,057
    543
    Nov 15, 2008
    Orlando, Fl
    I just had some tonight lol
  19. Ineedav8
    647
    Mar 1, 2013
    South Florida
    Chevron come on man and sprinkles!? Sprinles on the publix birthday cake ice cream is delicious Going to order another fuel filter for the car tho just to be safe.
  20. evilcw311
    7,459
    2,080
    May 9, 2010
    Louisville, KY
    If any of you have Zaxby's near by need to have the birthday cake milkshake with the sprinkles!!!!!!! :p
