Ford Racing Valve Covers
They are tall, but they do warn to check the height for the rockers. Only one way to really find out... You will probably need a spacer between the upper/lower to go with it to get enough room and then you may lose the use of the strut tower brace
dsrtjeeper
I'm using a carb intake with the Sniper 2.
dsrtjeeper
My engine is an 8.2 deck. I'd like to hear from anyone that has aluminum roller rockers and the Proform Ford Racing slant edge valve covers.
GTTRacing97GTS
Yup. I have a little trick that allows the valve covers to clear the alternator.
Gotcha. I run these covers and didn't know about the alternator problem at first.
I have the Ford branded Crane Cam rockers from a Cobra and these covers clear them fine.
I was wondering about this myself but it said it fit up to 95. I had to modify my fox body covers to fit my alt but I am running a larger 200A HO alt and wasn't sure if it was that, or the covers.
GTTRacing97GTS
Not to hi-jack this thread, but I actually run a smaller case alternator to clear my hood, and it still hit.
This first pic shows where it hit
Zoomed in slightly for detail
I didn't see any prior warning when buying these about the 95 front brackets, but I ended up making everything work.
FMGT1999
