found a solution to the banging in my front suspension.
daltonduree
omaha/lincoln, nebraska
well i think i found a solution the the banging in my front suspension. im replacing everything. control arm bushings, stabliser bar bushings, ball joints, shocks, shock mounts,while im ther doing cobra brakes and rotors.
kb1982
Kentucky
Darn, i thought i was gonna find the answer to lifes biggest mystery, but that should get rid of the banging lol.
daltonduree
i did moog bushings and moog problem solver greasable ball joints. kyb gr2 shocks and mounts. idk what my cc plates are but they are fine. im using oreilys remaned cobra calipers. both are real pbr aluminums. one has cobra on it and the other looks like its been machined off. for rotors using ebay drilled and slotted brakemotive rotors with powerstop pads
TanTop94
Maryland
I'm just glad he didn't find out it was me if his back seat. If you know what I mean;)
He meant fix it (regarding the banging in your front suspension)
9838stang
Minneapolis,MN
I have an issue with my suspension banging around. I have upgraded shocks struts springs bump steer and cc plates all at once. 4000 miles later i had this loud banging going on. found out that one of my struts, the nylon lock nut, the nylon itself completely wore out and was gone. so it came loose. got a new nylon lock nut and works great now no noise
daltonduree
well after replacing everything nothing but the stablizer bar bushings were toast. the shocks may have been maxing out. also found that one of the bolts out of the two for my motor mount are broken off in the block... great. i saw my longtubes are touching the unibody. and it may have all just been really loose
daltonduree
so today while installing the cobra calipers one of the banjo bolts striped out the caliper... i had to put a helicoil in there and that was very nerve racking.
wbarter
