Fourth day ownership got hit now build thread.
96laseredcobra
96laseredcobra
Farmington MO
lash adjusters and followers.
Sent from my SAMSUNG-SM-G890A using Tapatalk
lwarrior1016
Mr. Secondary Timing Chain
South Mississippi
Are all your lash adjusters easily compressed and still springy? And what coolant nipple are you talking about?
lwarrior1016
South Mississippi
Springy? And it's the valley coolant hose under intake manifold
You might need the water pump nipple being that you have a 1997. I think 98 changed. And when I say springy I mean when you press down on the top of the lasher, does it compress and feel like you are pressing on a spring?
96laseredcobra
96laseredcobra
Farmington MO
Not really just moves up and down
Burninriverdiver
When I did my pi cam swap my lash adjusters were solid as a rock...I bled them down using a c-clamp and two thick pieces of rubber to protect the metal. I thought they were toast, but after bleeding them down the correct feel came back and I haven't had any issues with them. It's worth a try since new ones aren't cheap in my book
96laseredcobra
96laseredcobra
Farmington MO
Thanks for the reply, I read online about the bleeding process I'll look into the clamp
96blak54
In the shop
All good info! These guys are good!
Hey I got an idea, just tske the crappy lashers and make them into solid lashers by breaking them down, gutting and welding completely collapsed. Then use those on the intake valves. Youll need to shim them up, but should make for interesting fun!
jarthur1995
