Front end overhaul.
the5.ohh
Shaolin, NY
Developed a squealing in the front end whenever the car is stationary and I turn the wheel. So it's either the tierod ends or balljoints. Everything in the front is original from 95, so around 58,500 miles on the front with the exception of the front swaybar endlinks and bushings I changed last year. I'll be doing the following, inner & outer tierod ends, J&M CC plates, Steeda X2 BJ's, New swaybar bushings
whiplash473
Northern IL
Moog ball joints, Maximum Motorsports bump steer kit, solid steering rack bushings
ElrodKTPQ_89
Crossett, AR
I think I'm in the same boat as you man. I'm waiting to do my struts and CC plates until I get everything else I might need, but I'm not sure what all needs to be replaced. We noticed last night while the car was in the air, if you grab the front wheels at 3 and 6 o'clock there is a lot of slack in the rack I'm guessing. Everything up front is original from 94 as well lol.
yeah skip the x2 BJs. Bumpsteer kit is honestly not a bad idea as well as the solid rack bushings.
the5.ohh
the5.ohh
Shaolin, NY
Any reason you're getting CC plates? Being only dropped an inch should be fine with the stock stut top plates.
Yeah, the tires are pointed in somewhat, and when I got an alignment after dropping it, it improved a lot. But they're still tilted in a bit. Tires wear fine so maybe I should skip them and save the $$
the5.ohh
the5.ohh
Shaolin, NY
I decided on moog bj's. Bumpsteer kit I just think is a little much for a daily imo. How hard are the rack bushings to change? I'll be doing all the work myself, I know its doable. Save a shit load in labor too.
MustangChris
Aurora, CO
swapping to OEM/Poly rack bushings is a 10 minute job. Going with solid is a 15 minute job (you have to cut the sleeve that holds the bolts, not a big deal at all).
glad you went Moog -- they're the best bang for the buck.
the5.ohh
the5.ohh
Shaolin, NY
Good to know. Some people were making it out to be such a big deal, dropping the whole rack and whatnot. Just watched a video, looks pretty simple lmao. Yeah I'll go Moog on the bj's. I was debating on just isolating the squealing noise, but I might aswell just do the balljoints, tierod ends (inner too), swaybar bushings and rack bushings
I hear ya. It doesn't have anything to do with being a daily driver though, it has to do with proper steering geometry. If your car doesn't pull over bumps then you probably don't need it.
the5.ohh
the5.ohh
Shaolin, NY
Gotcha. Nah it doesn't pull the wheel over bumps thankfully lol
Addermk2
That funny moment when you realize that Steeda's X2 balljoint is made by Moog
Regardless of who they're made by they seem to fail prematurely and from what I gathered there's no need for an X2 ball joint if you set up the rest of the front end properly.
the5.ohh
the5.ohh
Shaolin, NY
Ditto. I really appreciate the warning of the X2s, I'm getting Moog's soon. Thanks man
Vallybell
