For Sale FS/FT: 1995 Laser Red Mustang *Cobra Clone* Stroked And Blown 355 Dart Block
armyed
Been going back and forth about selling this thing for a few years and I think it's actually time that I'm going to do it so I can get into a newer 2011-2015 5.0 turbo car. Car has the full A/C setup (Car runs to hot for my taste during summer with A/C on) and heat. It is in need of a paint job but the Laser Red still looks pretty good. Rear passenger tire rubbed when I first went with a large rear tire and waved the fender were the tire was close a little bit. Car put down 636RWHP with the Vortech SI blower, 2.95 pulley and stock Vortech crank pulley. The motor/drive train in the car is capable of so much more, I just never tried to go crazy with the power(Bigger Blower). The car is located in Marietta Ga. I'm out of the state/country a lot of the time but could always set something up. Here's a list of most of the stuff done to the car. I'm sure im missing some stuff in the list that was just replacing old parts but most of the stuff in in there. Car has almost 158k miles on it, Engine/Drive-train has no more than about 5000 miles (If That) on it. Last time I weighed it the car was 3450lbs with 1/4 tank of gas and me not in it. Thanks [email protected]
Price Updated
$13k OBO Or Trade
Anthracite FR500 18x9 Fronts 18x10 Rears
265/35/18 Nitto 555 Front tires (1000 Miles)
305/35/18 ET Street II Mickey Thompson D/R's Back (1000 Miles)
Saleen S281 Wing
Cobra Crystal Clear Headlights
Cobra 160 MPH White Faced Instrument Cluster
Auto Meter Shift Light inside A/C Vent
Suspension:
Eibach Sportline Springs
Strange Engineering 10 Way Adjustable Struts
Strange Engineering 10 Way Adjustable Shocks
Slotted and Crossed Drilled 13 Inch Cobra Front Brake Setup Brembo Rotors
QA1 4 bolt Caster/Camber Plates
New Polyurethane Bushings Front Sway Bar
Edelbrock Dual Adjustable Upper Control Arms
UPR Lower Control Arms
Dart Iron Eagle Sportsman block 8.2 deck 355 Stroker built by Mo's Speedshop (.30 Over, long throw)
Eagle Stroker kit
4340 Eagle crank
Forged JE pistons
4340 H beam rods
Vortech SI Supercharger with RR 2.95 pulley (1000 Miles)
Vortech black powder coated discharge Pipe
UPR Power Pipe
Mr. Freeze Meth Kit(Big Nozzle)
Comp Cams Hydraulic lifters
Comp Cams Ultra Gold 1.6 RR's
Billet Cam (Forced Induction Spec, honestly can't remember which one, 560ish lift)
Trick Flow 75mm TFX Throttle Body (Fox Setup)
60# Injectors
80mm MAF
ACCEL Extreme 9000 Ceramic Spark Plug Wire Set
NGK Spark Plugs
Smog Pump Delete Pulley
99-04 GT Ford Clutch Cable w/UPR Adjustable Clutch Quadrant
Black Powder Coated Holley Systemax Intake
Ported Edelbrock Victor Jr 60cc Heads 2.05/1.60 205cc w/Cometic head gaskets
Comp 929 Springs
Aeromotive Stealth Fuel Pump - 340lph In Tank / T-Rex inline Secondary Pump
Edelbrock Intake Elbow EGR Delete Plate
Cobra Front Brake Set Slotted/Crossed Drilled Brembo Rotors
Adjustable Fuel Pressure Regulator
Powermaster PowerMAX Starter 9103
Energy Suspension Poly Motor Mounts
2 Flu Aluminum Radiator
Chrome Overflow Tank
Mr Freeze Meth Injection
6AL-2 Ignition Box w/2 step (2 step not hooked up yet)
SCT 4 bank chip tuned by Mo's Speed Shop
Trans Back:
TKO 600 26 Spline
Energy Suspension Poly Transmission Mount
Pro 5.0 Short Throw Shifter
Spec Stage 3 Clutch Setup
Ford Racing Aluminum Drive Shaft
Ford Racing 3.73 Gears
8.8 With Welded Tubes
Moser 31 Spline Axles
Ford Racing 31 Spline Trac Loc w/ extra clutch
Exhaust:
1 5/8th Mac Equal Length Headers
2 1/2 Inch Off road H-Pipe
40 Series Flows
Chrome exhaust tips
Seeley4jeff
