Adam Vinnicombe
- Joined
- Jun 28, 2019
- Messages
- 498
- Reaction score
- 71
Ok I will swap them out and see what happens.
Hi all I’m about to replace my injectors on my new edge GT which have the pink injectors in it, anyway I went to get some more and was told that these were the wrong injectors, is this true ?
What injectors are you kit running?
I have all the bolt on mods you can have except cams.
The next question is what should my fuel pressure be at when at idle and WOT?
My tuner is saying I have 38.4 to 40 psi at idle and 43 max reading at WOT.
I am running a SVT fuel pump if that makes a difference or not?
You could get the part number from the regulator and call aem to find out if they have a lighter spring to go inside the regulator and lower the pressure. If you’re swapping back to the stock stuff, disregard what I’m saying.
So the stock regulator is putting out 50 psi or the one you showed? I though to put the stock regulator back on you would need to put the stock rails/fuel lines? This one looks to have AN fittings is why I ask and doesn't look like a stock replacement.What is in the photo is most definitely what I had fitted. I’ve now got the stock regulator fitted
