Apr 6, 2022 #1 C Cetz New Member Joined Sep 7, 2021 Messages 2 Reaction score 0 Hi I have a question can I run my fuel pressure gauge from my fuel pressure regulator. Or it has to be ran from fuel rail?
Apr 6, 2022 #2 ttocs Post Whore Joined Oct 9, 2009 Messages 32,646 Reaction score 5,661 Location Evansville Indiana There are no spots on the factory regulator to tap for pressure that I am aware. Depending on the year the schrader valve on the rail is the easiest place.
Apr 6, 2022 #3 RAU03MACH Legend Joined Apr 23, 2019 Messages 6,842 Reaction score 6,680 Location NEW MEXICO Better off installing a permanent gauge on the rail That way its visible
Apr 6, 2022 #4 OP OP C Cetz New Member Joined Sep 7, 2021 Messages 2 Reaction score 0 RAU03MACH said: Better off installing a permanent gauge on the rail That way its visible Click to expand... I have after market regular and trying to put gauge in the pillar
Apr 6, 2022 #5 ttocs Post Whore Joined Oct 9, 2009 Messages 32,646 Reaction score 5,661 Location Evansville Indiana you can still put the sender in the rail. If not you would probably need to switch to AN lines and add a spot for a sender/sensor.
Apr 10, 2022 #6 Makoto Active Member Joined Nov 24, 2016 Messages 839 Reaction score 745 Location Houston Cetz said: I have after market regular and trying to put gauge in the pillar Click to expand... same process. i have a gauge on my rail before the FPR. what you want to gauge is the pressure at the rail BEFORE it sends fuel back to the tank.
